Sweep on outer edge
Sweep on outer edge
sick.yoon
Sweep on outer edge
sick.yoon
Hi, I am learning about fusion 360 sweep feature.
I would like to extrude a text in circular fashion 90 degrees from bottom to front.
However using curved path, resulting model sweeps it based on lower edge of the text.
This raises the text higher and I would like the bottom of the text to be touching the bottom plane.
Is there a way to sweep based on the upper edge of the text?
matthewrjacobs
Did you try revolve around the X Axis 90deg?
sick.yoon
That worked! Didn't realize there was revolver tool!
mango.freund
hello @sick.yoon  but yes, just work in the other direction, or from an offset level down. BR mango
