Shell refuses to work on my spheres
kest_cesnavicius
kest_cesnavicius
Good evening
Shell refuses to work on object with added spheres.  Error:   The operation could not create a valid result. Try adjusting the values or changing the inputs.  Tried to use shell at multiple point in multiple layers but can not be used after first sphere was added.
jhackney1972
You can use a different approach and get a shelled body.  This is a 2mm wall thickness.  Model is attached.
John Hackney, Retired
kest_cesnavicius
I see your strategy. Creating two surfaces. Except there is problem again. Ofset is only allowed up to 2.7mm while I need at least 3mm.
TheCADWhisperer
@kest_cesnavicius
If it were my design - I would start over to clean it up, but in any case - see Attached...
Oops, I forgot to make the component Active, but you get the idea.
I suspect the design technique could be significantly simplified.
A couple simple sketches.
A couple of Revolves and Loft.
Shell and done.
kest_cesnavicius
Thank you so much. I will do so
Just started learning modeling after first 3D printer.
