Joining bodies together
karl
karl
If I have two irregular bodies I move close together and want to join into a single body, is F360 able to automatically sort of "weld" them together, filling in any gaps between them, or is that something I should do manually using sculpting tools (or another program completely)?
jhackney1972
No, the two bodies must intersect or touch.  Then you must use the Combine tool to merge them together.
Edit: You can of course add a third body to fill in the gap between the two original bodies but the same rules apply.
John Hackney, Retired
