In the attached file, I've imported a .OBJ of a round disk with a hole pattern in one side. The other side is a flat solid face. I'd like to cut a hole in this face a little smaller in diameter than the disk. I was unable to create a sketch on the face, so I created an offset plane, sketched the circle, and tried to extrude it to cut through the face, but this generates the error, "No target body found to cut or intersect." Do I have to somehow convert the imported .OBJ before performing operations on it? Thanks for any tips.
