Sheet Metal
Sheet Metal
mariusche
Message 1 of 33
Sheet Metal
mariusche
Hello
Replies (32)
Message 2 of 33
TheCADWhisperer
I didn't finish it, but you get the idea.
Message 3 of 33
SaeedHamza
Here is a screencast to make it clearer
Regards
Saeed Hamza
Message 4 of 33
mariusche
Hello
Thanks so much
Yes it is what I want
It is possible to receive project file?
Message 5 of 33
mariusche
Thanks for screencast
but I did not understand exactly what you are doing when project the edge, project the same edge twice (in the timeline 38s-44s)
Message 6 of 33
SaeedHamza
Never mind that, I was trying to get a closed profile to make a flange of the same outline of the main body that's all, you can forget about the projection and sketch your own
File is attached
Regards
Saeed Hamza
Message 7 of 33
mariusche
I need like this
Message 8 of 33
daniel_lyall
just cut that bit out then put a new flange in it have a look at the attached file
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 9 of 33
SaeedHamza
Okay, this is the same as the screencast above
Do you mean the whole thing?
Saeed Hamza
Message 10 of 33
TheCADWhisperer
@SaeedHamza
I don't understand why you attached this file as an example - it does not represent a proper sheet metal part.
Message 11 of 33
SaeedHamza
@TheCADWhisperer
Could you explain what isn't proper about it?
Saeed Hamza
Message 12 of 33
TheCADWhisperer
No.
I recommend that you walk out to the shop floor and attempt to fabricate the part as you have designed it or ask an experienced sheet metal person to fabricate it for you from your design.
Or just sit at your desk with a sheet of paper and attempt to fold it up as you have designed.
Message 13 of 33
SaeedHamza
@TheCADWhisperer
If you can't explain why, then please don't judge it from the very beginning!
This wasn't made for fabrication, it's simply to show how to get that small part with the fillets, nothing more!
Saeed Hamza
Message 14 of 33
TheCADWhisperer
@SaeedHamza wrote:
..then please don't judge it from the very beginning!
You post a "solution" on a public forum - I will judge the design.
I am interested in more than mere "pretty pictures", I am interested in Design for Manufacturability.  Otherwise I might be using Photoshop rather than MCAD software.
The users here (especially the beginners) deserve correct solutions.  Many are beginners who do not have enough experience to judge the information they are being presented here.  They expect that they are being given the expert solution.
If I post an incorrect solution - I expect to be judged for the error.
Message 15 of 33
SaeedHamza
Okay that's good, so since my solution isn't good, the beginner should at
least know why!
If you provide an explanation, maybe both me and him can learn something
new, but you didn't
We're here to help and learn after all
Saeed Hamza
Message 16 of 33
TheCADWhisperer
If I get a chance - I will finish the part for the OP later today.
Right now I have to get my paid work completed.
Check back later.
Message 17 of 33
SaeedHamza
Looking forward to it
Saeed Hamza
Message 18 of 33
TrippyLighting
Spot on!
Message 19 of 33
daniel_lyall
@SaeedHamza Have a look at what I did, you just need to move the timeline to see it and if you have a close look at what @TheCADWhisperer did you will see there is not much differences.
A simple part like this you only need a sketch for cutting the shape out,(this is how I do it, it may not be the correct way to do it and if I am wrong I expected to be judged in a constructive way) I did it so you could unfold the cutout if you wanted to without unfolding the rest of it, or so the angle of it can be changed from 90 to 0 or 180.
Also when you make the flange if it looks like it's in the wrong spot change it's position useing what's in the drop down menu.
Daniel Lyall
The Big Boss
Mach3 User
Message 20 of 33
SaeedHamza
Thanks for the explanation @daniel_lyall
Much appreciated
Saeed Hamza
