I added a new Sheet Metal rule for "Steel 1mm".
When creating a new Sheet Metal Component and I want to select the correct rule,
the "Steel 1mm" rule I made is not showing up.
Is there a way to solve this.
Thank you.
Hi! The behavior does not sound right to me. It could be a corruption or there is a duplicated style. Please share the f3d file here. The forum experts can help take a look to understand the issue better.
Many thanks!
I have noticed this too. It is like my list of sheet metal rules are too long for when I create a new component. This is even with a brand new document.
If I create a new component or bring up an existing component and go to change the sheet metal rules for that one. The list just ends after 35 sheet metal rule items.
Hi! The support team shares the file with me. I can confirm the behavior. Indeed, all the Sheet Metal Rules from sheet metal parts within the assembly are aggregated to the list. Currently, this is a deficiency in Fusion Sheet Metal environment. There isn't a workflow allowing users to manage the Sheet Metal Rules from a library. It is always on a per design (model) basis.
The support team will report a ticket so that the project team can take a closer look.
Many thanks!
