Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Sheet metal error on flat panel
2 REPLIES 2
javelin_exile
224 Views, 2 Replies
javelin_exile
Hi Folks
I'm making a simple tray. flat with 4 flanges and features on the flanges and I keep getting this error when I try and generate a flat panel should I just start over again and see if it works or is something wrong here that I'm not seeing?
Error: "Failed to identify sheet metal faces for some edges. Ensure the body is a valid sheet metal body that keeps opposite faces separate".
Hi Folks
2 REPLIES 2
jhackney1972
You have joined the corners where it needs to unfold.  Video will explain.  I did one end and that model is attached.
John Hackney, Retired
javelin_exile
That was definitely the problem. Thanks!
