Share drawings from different assemblies/projects in the same web directory?
charlie.buscher
charlie.buscher
Is it possible to sharing multiple drawings/sheets from different assemblies in the same location on the "FUSION WEB" ? The web share is very useful for someone who doesn't want their drawings downloaded but sending individual links to each drawing would be cumbersome.
Importing sheets to other assemblies using the same component would solve this but the move and copy function on the web is not working (yet?).
lucasliraAU
Hi, @charlie.buscher !
I believe that the best option for your workflow is to save all your sheet drawing files in a single project folder and access https://myhub.autodesk360.com/ via the web
You could invite a member to be part of this directory so that the guest will have access to all the project information.
I hope this helps you in some way with your workflow!
Greetings from São Paulo - Brazil.
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
charlie.buscher
If I'm understanding correctly, using that method the viewer would have to have an Autodesk account.
I'm needing to "securely" share drawings with a customer who is not an autodesk user and I'd prefer to make them jump through as few hoops as possible.
The Autodesk hub is extremely useful for this sort of thing.
For now I've  integrated links to the drawings within our parts productions schedule.
