Shaped Pocket
Shaped Pocket
Richie_B
Message 1 of 8
Shaped Pocket
Richie_B
Could anyone please explain how I can extrude the pocket in the picture, but have the base of the pocket curved like the top
Richie
Replies (7)
Message 2 of 8
g-andresen
What do you want to achieve?
with Modify > offset face you can change the depth of the pocket.
share the file
File > export > save as f3d on local drive > attach to post
günther
Message 3 of 8
Drewpan
Create your shape from the side.
Extrude the shape
Create a sketch of the bit you want cut out.
Extrude cut offset from the plane.
Job done.
Cheers
Andrew
Message 4 of 8
Richie_B
yes that's what I get but I would like the bottom of the pocket to be curved as well
Message 5 of 8
Richie_B
thanks for the reply. I think I have just figured it out using ' Start from object '
Message 6 of 8
Richie_B
Thanks for the help. I have worked it out (see above)
Message 7 of 8
laughingcreek
extrude from-
Message 8 of 8
Richie_B
That's great, Thankyou
