Can not open DXF.
Can not open DXF.
scastrophotography
Can not open DXF.
scastrophotography
I am having trouble opening a DXF file. I have used the data panel to upload it and it is now visible in the folder in the data panel. But when I go to open it, fusion tries for 20 min so far and nothing has happened. If i try cancel it, fusion will go to not responding. I dont know what is going on. Is the file to large? its 800kb in size, could i try a DWG. file instead which is only a fraction of the DXF file size? I rather not share the file publicly, so If someone would take a look, I could sent it to you.
I did manage to open the DXF in question, in pretty quick time using the Autodesk Viewer online.
Kind regards
Joshua
g-andresen
workspace > INSERT > Insert DXF  > select plane and file > ok
günther
scastrophotography
Thanks Gunther.
That brings up this screen, what do i choose for insert mode?
Joshua
g-andresen
Insert DXF
(view in My Videos)
If this does not work, please upload the DXF
günther
scastrophotography
Thanks for that, That is what I see, but it will not open. Can I send it to you in a Private message? I dont really want it to go on a public forum.
g-andresen
@scastrophotography wrote:
….Can I send it to you in a Private message? I dont really want it to go on a public forum.
I only act publicly in the forum.
günther
scastrophotography
Okay, hopefully someone else will chime in.
