Setting structural constraint
How do you choose what structural constraints are you going to apply in generative design? I still cannot fully understand how to choose them. For example, I am optimizing a cylindrical material that needs to overcome 100 N of tensile forces. Commonly to test this physically, a universal testing machine would be used which clamps the two ends of the cylinder and apply tensile force. In deciding how to put structural constraint, should I simulate the physical test in the generative design? In other words, should applying constraint and load sbe based on how the product would be tested in real life?
I_Forge_KC
Thinking about how a test rig works is a good start sometimes. In your example, one end would be fixed (constrained) and the other end would be pulled (force).
A quick word of caution here. If you build loads that are pure tension or pure compression then you run the risk of creating unrealistic results. Technically, pure tension/compression only requires a small cross sectional area. This means that any eccentricity to that load will immediately cause it to fail. Just something to think about.
K. Cornett
Generative Design Consultant / Trainer
Do Autodesk offer some materials/training/webinar about setting constraints and loads during generative design?
I_Forge_KC
The basics are exactly the same as any FEA system. That being said, there are gen design tutorials out there though I'm not sure any cover the minutiae of constraint/load development. You may want to brush up on general simulation constraints. Here is a Lars video that walks you through some good stuff.
https://youtu.be/bZnHQTPP-Ps
K. Cornett
