Load Cases on Generative Design
How does generative design account for multiple load cases? Does the software generate a solution for each load case or are the solutions generated to satisfy all load cases at the same time?
I_Forge_KC
Simultaneously satisfied.
If you were to have a load case that was purely horizontal and a load case that was purely vertical, then you would end up with a diagonal solution that satisfies both.
K. Cornett
Generative Design Consultant / Trainer
I wonder if there is no option for the genrative design to solve for a single solution that can handle each load at different times, not necessarily experiencing all load cases at once.
I_Forge_KC
Think of each load in a load case as happening at the same time. Think of each load case as happening one at a time. The result will satisfy any of the given load cases (individually).
K. Cornett
So if we wanted different results for different load cases we would have to make more studies?
