Set current view as top
After doing a couple "Change current view to top", the red,green and blue axis lines all turn black.  This did not happen before the last update.  I have to restart fusion to get the colors back.
Using a 3Dmouse, and switching from multi view back to single view, the 3Dmouse looses focus and will not work.
Why does the X axis always revert to the wrong orientation when clicking the "top" button?  it is 90 degrees off.  Every other program I have ever used shows the X axis as a horizontal line when doing a top view.  This also matches most VMC's  I know it can be rotated manually, but with multi views it gets confusing.
Todd
NicolasXu
Hi Todd,
Thanks for your feedback regarding multi view.
For the 3D mouse issue, I can reproduce it and will ask the development team for a solution. (The tracking ID is: FUS-16156)
For the X axis issue, did you work on a Z Up design or Y Up design? I will forward it to the team to take a look.
Best Regards,
Nicolas Xu
Sr. SQA Eng.
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Z up.
If you go to front view, it shows a green ( Y ) line horizontally. This is incorrect. It should have a red line horizontally on a front view and a green line horizontally on a right view.
The way it is laid out now, everything is 90 degrees out of how it sits in real life on a milling machine. I know it can be changed, but it reverts on every new drawing and is just confusing to machinists.
On a front view, X+ and X- should show as a red line, left to right on screen, not a green line. Red=X Green=Y Blue=Z
Todd
NicolasXu
Hi Todd,
Thanks for the confirmation. I have forwarded it to the team to review the situation.
Thanks for providing the details. Please keep feedback coming!
Nicolas Xu
Sr. SQA Eng.
Autodesk, Inc.
I'm going to bump this question again, when I start a new drawing and click the top box, why is top box show up 90 degrees rotated from real world coordinates?
When I click set current view as top, it rotates the top box and the red and green lines -90 degrees.
I have attached 2 snips.  I want the top box to be horizontal and the red line to be horizontal.
Todd
