Separate sketch circle in to two points
I have one circular sketch. I need cut it in to two sketches,but line must be copied and not literally separated from circle. I created two sketch points, but guess it does not work.
g-andresen
1. create 2 lines
2. select "break" tool
3. copy selected element
günther
Thank you, i already found another solution, but this method is also applicable!
