Is there a function to retrieve the unitless version of a user parameter?
bassbonematt
bassbonematt
When creating user parameters, I often need to use exponents, square roots, etc., and these math functions either require unitless input, or when given unit-ed input, the resulting output no longer matches the unit of the parameter I'm defining, e.g. if x=2 in., x^2 results in 4 in^2, which means the unit for the parameter must be in^2.
Is there a function to retrieve the unitless version of a parameter? That would solve this problem, but if you have other tips to work around this, I'd love to hear them! Right now, I end up defining two different versions of the same parameter--one with a unit and one that's no unit. That kinda sucks.
g-andresen
for your example: 4 in / 1 in = 4
günther
bassbonematt
While that's kinda clunky, it's a step better than what I had been doing. Thank you! I would still like to see Autodesk implement a function to retrieve the unitless value of a parameter, though, as that would be even cleaner.
g-andresen
in such a case I define a user parameter „ Unit“  > value = 1in
günther
HughesTooling
You can just divide by the units, no need to add the 1.
Mark
Mark Hughes
Owner, Hughes Tooling
