If you go to the patch workspace you can unstitch all the surfaces. Then make components for each part, drag the surfaces into the correct components, then hide all but the component you're working on then stitch and patch back in to solids.
Another option might be Boundary Fill, draw planes at the intersection points and use them to split the body up.
Mark
Mark Hughes
Owner, Hughes Tooling
