Selecting surfaces in simulation
Hi everyone,
I've a problem in simulation section. I've a quite complex geometry, so I want to avoid mesh problems (see image). I decided to simulate my model with fusion 360. The first question is, if I get accurate results with Fusion 360? Or should I use an another FEA program to solve this model? And second question is: I have to select inside surfaces to define loads. How can I select these inside surfaces in simulation mode?
Thank you for your help.
rushabhthakkar_910
Can you Attach your File here..
File> Export> Save to Local Drive> Attach it here...
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
thank you for help. I couldn't select all surfaces to define load condition.
mango.freund
hi @Anonymous can't you find the answer to the selection filters?
maybe you have to generate a surface color first.
I don't know, but I'm interested in what the solution will be. -------greetings mango
hi mango_freund,
 there are a lot of faces in the design. I can't select all of faces, so I need a filter to select all tangential faces. I think it should be a option like "add tangential faces". But I didnt see it.
mango.freund
hi @Anonymous it was only in my mind, but a lot of new things are there now.  mango
