select face to select all edges for filleting
cekuhnen
Mentor Mentor
Message 1 of 9
cekuhnen
Fusion cannot select all edges of a face when filleting when clicking just onto the face.
you can only manually select non tangent edges or draw a selection, which itself has problems based on design complexity
so it would be good if like in the image blow I just click on the top face and it selects all logical edges!
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Replies (8)
Message 2 of 9
taylor.stein
Hey Claas - this would be some nice functionality. Have you used the Rule Fillet command? The Rule Fillet allows you to select a face and add fillets to all of its associated edges. This behaves parametrically, so if a prior sketch that drives the face is changed all associated eges will be fillet-ed (even if the number of edges increases/decreases).
Let me know if you have any questions!
Taylor
Taylor Stein
Fusion 360 Evangelist
Message 3 of 9
keqingsong
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Message 4 of 9
kelotrbrbr
Why is the Rule Fillet function only available when design history is selected?
Message 5 of 9
schneik-adsk
Rule fillets are dependent on parametric updates and will update to changes in shape in the timeline.  I see the value to being able to get the same result in direct. But they would not be rules like they are in the timeline.
Kevin Schneider
Message 6 of 9
cekuhnen
@schneik-adsk Not that this was applicable to my design but when possible the ruled fillets is a pretty sweet tool to have!
Claas Kuhnen
Message 7 of 9
kelotrbrbr
I've tried double-clicking an edge to select the edge loop but it doesn't seem to work either.
Message 8 of 9
@kelotrbrbr double-clicking edges to select edge loops works only with T-splines (sculpt environment)
Message 9 of 9
kelotrbrbr
