select all profiles within a sketch during extrude?
subversivespeed
Message 1 of 15
subversivespeed
I have a sketch that is imported artwork with lots of detail..
No way am I going to sit there and click every profile...
How can I select all profiles within a sketch to extrude? I couldnt' seem to find anything about it...
Replies (14)
Message 2 of 15
etfrench
Have you tried using the Window select?
ETFrench
Message 3 of 15
sanket223.patil
Hey , I also some time need to extude alot of profiles . Window select is best option .
Sanket Patil
Mechanical Engineering
Expert Elite
Message 4 of 15
melvinbrian3d
You have to use a selection tool like.... Window Selection , Freeform Selection or Paint Selection to quickly grab multiple sketch entities or profiles, simultaneously, as in put for the extrude command.
Link: 3 ways to select an area in Fusion 360
MelvinBrian3D
Message 5 of 15
subversivespeed
Yes, however it has some unusual results.
Message 6 of 15
sanket223.patil
@subversivespeed
Can you share your file , So we can provide you proper solution .
Sanket Patil
Expert Elite
Message 7 of 15
melvinbrian3d
After you've selected all sketches, you can unselect if you do not want any or various sketches by pressing SHIFT+ Left Mouse click
MelvinBrian3D
Message 8 of 15
chrisplyler
Did you mean Profiles? Sketches cannot be selected for the Extrude tool input.
Message 9 of 15
melvinbrian3d
Yes Sir... i Mean Profiles... somehow i wrote sketches!! O.o
MelvinBrian3D
Message 10 of 15
etfrench
'Unusual results' doesn't give a clue as to what they are.  Attach your file to the thread (File|Export|Archive files *.f3d) or make a screencast.
ETFrench
Message 11 of 15
subversivespeed
Still working on this, however I cannot open the file today.. Will have to wait until server is up. I did have some success using a slightly different dxf generation algo.
I wish that the dxf tool had a cleanup / gap connect algorithm. Currently I am having to pick through and find all the small gaps manually. I think the dirty dxf is most of the problem, however, that is somewhat of a regular thing with any software and Solidworks et al. have dxf cleanup routines with gap jump, smoothing, etc.
Message 12 of 15
TheCADWhisperer
What is the name of SolidWorks tool?
Do you have a citation of reference link?
Have you attempted to run the SWx tool on your dxf?
Do you have access to AutoCAD?
Are you a student?
Can you Attach your dxf File here so that I can test in SWx and AutoCAD?
Message 13 of 15
subversivespeed
https://www.youtube.com/watch?v=A7SooO7mZlQ
Solidworks / "REPAIR SKETCH"
Message 14 of 15
khushaldas.badhan.001
"Select all and deselect what I don't want" That is so much of overwork. Thing which can be done in 10 secs, will take a 2-4 minutes and lot of frustration.
Message 15 of 15
etfrench
Tell your boss not to be so cheap and buy that psychic computer.
ETFrench
