I'd like to 3D print a filter adapter to fit over the hood of this lens. I envision a round ring that accommodates the hood contours (for orientation) on the camera side with a flat surface on the opposite side to which I'll glue a round filter adapter allowing me to screw in standard, round filters.
I can imagine several ways to fasten the ring to the hood (e.g. make a radial slit all the way through the ring and bridge it with a screw to cinch the ring tightly to the hood; while not a fast or convenient solution, I'll probably leave the ring on all the time with a UV filter to protect the lens), but thought I'd check in here for better ideas. Thanks.
Solved by etfrench. Go to Solution.
The screw method will probably be the most secure.
You could also use an O-ring to make a slide on holder more secure.
Do you have a larger image of lens?
ETFrench
Personally I would go with a friction fit. Measure the outside diameter of the lense's hood. Model your ring with an inside diameter a couple thousandths smaller. Print it.
Test fit and sand out the interior diameter of the ring until it pushes onto the hood but won't pull off easily.
Here's another way:
Make it a friction fit and make it more secure by adding tabs to catch on the back of the hood.
The other thing to consider is blocking stray light from hitting the front lens. Here's how I did a hood for my 60mm lens:
Any light rays that don't directly hit the lens are reflected back out.
ETFrench
I think your solution with the clips is the way to go, etfrench. There are some tight tolerances involved to get it to work, but it shouldn't take more than a couple of prints. Thanks.
This is a good idea, chrisplyler, but it's so dependent on the right fit I'd be worried about ambient temperature possibly making it expand and come loose. Might never happen, of course, but etfrench's idea of a friction fit with retaining clips (below) mitigates that risk.
