sculpted and parameters?
 I have created a spline, turned it to pipe and sculpted it into a shape I like.
Now I want set up a parameter to change the over all high and keep it in proportion.
Can Anyone please help, or point me in the way of a good video.
Thanks pauric
see pic; if this was a leg of a table and I want the same design for a low coffee or dinning table or a tall standing breakfast table. any help or tips on how to set up a parameter that I can input the table hight and it all will change change the shape and stay in proprion Screen Shot 2016-05-28 at 14.31.15.png
PhilProcarioJr
@Anonymous
I could be wrong but I don't think this is possible. Modifying surface models created from splines is one thing but you are want a driven T-Spline form. All my attempts to do this were unsuccessful.
Phil Procario Jr.
Owner, Laser & CNC Creations
Thank you for your resopnce.
yes im begaining to think that myself too.
maybe im going about it the wrong way?
Is their another way to make an orgainic shape that over all is parametric?
thanks for your help/trying 🙂
PhilProcarioJr
@Anonymous
"Is their another way to make an organic shape that over all is parametric?"
This depends on how organic the form is. For the piece you pictured above I think I would use the loft tool. That can be parametrically driven.
If you really like the form you already made you could....
Go back into T-Splines and turn off smoothing of your leg so it looks blocky then export that as an .obj file. Then you can upload that obj file in fusion and convert it to a B-Rep and use it to make your cross sections with rails by snapping to points on your original form. It would be a lot of work to setup but would give great results if you want to keep the form you already made.
Phil Procario Jr.
thanks phil for you help. i will have a go at lofting the shape this evening. this shape was only a test shape to experiment with but it is something simular.
thanks for you help. i will have a go at lofting the shape this evening. this shape was only a test shape to experiment with but it is something simular.
