how to cut a solid using profiles in 2 different planes?
Hi everybody! I have encountered this problem several times. It is not actually a problem, but a curiosity. Does anybody know the best way to cut a solid using profiles found in 2 diferent planes? Probl.png
As you can see, I have an elevated section which I had to achieve by deleting the extra material around it. It used to look like thisprobl2.png
If anybody knows what is the best (safest) way to do it, I would be very grateful. The way I did it left my model with an extra circle and I suppose it is not the best approach.Circle.png
TrippyLighting
This looks strangely familiar 😉
Coould you share your model (export as .f3d and attach to next post) so we can take a look at it ?
Yeah, why not. Here it is.
Thank you for still helping me! 🙂
TrippyLighting
Your last split body opertion creates three bodies in your "Base:1" component:
Insead of removing faces, from body "Case (1) (1)", which will leave you with remaining and probably useless faces, you should remove (not delete) body "Case(1)(1)" and then modify->combine(join) bodies "Case" and "Case(1)".
Start by deleting the last two DeleteFace operations.
First of all I would like to ask you again what your name is because I forgot. And then, I would like to say I am very pleased that there are people like you!  You are awesome!
TrippyLighting
Peter 😉
