Scaling splines broken
petttkous
petttkous
So when I make a shape using splines without changing any of the points after I placed them the scaling works as it should be but when I change anything on that shape, the whole scaling breaks completely. Example below.
Shape with no changes at allShape with no changes at allScaling of the original shapeScaling of the original shapeOne point modified a bitOne point modified a bitScaling of modified shapeScaling of modified shape
Do you have any ideas what could be causing this and how it could be fixed? It's really frustrating...
SwApNiLbAd
Hi @petttkous  you have to preselect the sketch which you draw then use scale option.
(As splines is consist of many entities in your drawing but you have selected only 1 entity so when you scale your sketch only one entity change its length other entities not ,so select the sketch then use scale option)
I hope this will help you.
g-andresen
I have tested it and found that the error occurs when the tangent handles have changed.
Moving control points alone is ok.
kind regards
günther
petttkous
Nope, doesn't work, the problem is what @g-andresen described.
