Message 1 of 9
- Mute
- Permalink
- Report
Hi
I have a blueprint that is scaled already and is A0 or A1, which ever is the largest.
I plan to create a 3d object using it as a starting point but when I insert into Fusion it inserts small and then I need to scale up to some measurements I already have.
It would be good if I can insert it in at the scale it already is saved as, is this possible?
The reason I ask is that I loose accuracy by scaling it to a known line I have drawn and inserting as is would be better.
Any advice will always be appreciated.
Regards
Ian
