Scale 1 face of a body?
Hi
I am trying to scale one face of a body, to create a taper between top and bottom. However each time I active the scale function, it selects the whole body?
Is there a way of doing this within Fusion?
Anton
jodom4
Hey anton.zdziebczok, welcome!
You can definitely make tapered geometry, but the scale tool doesn't work that way. Here's a video on the Draft Angle tool, which will probably solve your problem:
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
Jonathan
Thank you! This is exactly what I was looking for, I did try the draft tool previously, but I hadn't understood the importance of the pivot plane correctly, so thanks for this! I am coming from Google Sketch-Up so these commands & tools are totally different!
I have stumbled across my next issue though...
Having created two shapes, I want to re-engineer a section to have a slight tilt to it. In Sketch-Up I could simply move the end face on the vertical axis to create a "bend", but that method doesn't seem to work in Fusion. I don't want to use the sweep feature as the component/body already exists, and the section already has a taper on the side.
The section currently looks like this...
These blue lines represent what I am trying to create...
Sorry to ask so many probably silly questions!
Anton
davebYYPCU
If two bodies, then Move Tool and rotate from top face.,
If one body, use Split body at Hinge position, and then Move Tool, then Combine join them
there are other ways to make the shape.
Dave
Thanks for these suggestions. It gets me part of the way to the desired outcome, but not all the way!
It is already two seperate bodies, when I rotate the section to be turned down, it creates the desired effect, but as expected, leaves a gap at the top where the component has pivoted around the bottom access as per the below image.
I have tried to fill this gap with various different tools in the patch space, but don't seem to be able to create the correct gap.
Any thoughts on how to close this gap?
irndolf
Community Visitor
Community Visitor
Hey Jodom4,
Have you tried doing it in a complicated 3D Model?  I tried using tapered with this shape and its taking way to long and scale function doesn't work well with this. I find that the Scale is only good for Solid Components. Are there any other way I can do a tapered side with this type of plane?
I hope you can help me @jodom4
