saving animation and convergence plot
as regard the results in a finite element analysis in fusion 360  how can i save the animations of the resultsin my computer
also how can i save the convergence plot in my computer
as regards the convergence drawing there is percentage called actual %, target % how can i explain them what are their meaning
lucasliraAU
Hello To my knowledge the Fusion 360 platform still does not generate animations in mp4 of the simulation analyzes. But nothing prevents you from taking a screenshot.
The recommendation is to work with the traditional parameters as the analysis tables.
You can use the result - report feature to get all the results in detail about your analysis.
I hope this can help with your work!
Greetings.
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
