Running Slow as design gets more complex - How Can I improve this?
My design has maybe 10 components, 10 Sketeches, 1 Mesh but over a period of time it gets to a point where most operations are taking a long time e.g. delete a line from a sketch an CPU fans are working overtime while Fusion has a big think about things.
What can I do to improve this?
All components are fairly simple but I do use/need a lor of dimensions/comstraints (upto 50?) in the sketches.
All other components and the mesh are made non-visible
I tried copying the components I'm working on and pasting in a new document thinking I could then delete the old and re-import the revised component when I'm done but the paste does not work.
I thought I could delete some components to try and see where the issue is but I don't think delete will work - at least I should use remove but all the history is stil in the time-line so I don't think that will help..
I could turm the time-line off but I don't want to loose all base sketches etc
It would help if I could work out why when editing a simple sketch it is using so much CPU?
I'm currently on a trial for a subscription - is it worth contacting Autodesk?
I can't attach the file it's too big 128Mb - probably because of the scan.
My Laptop is 11th Gen Core I7 32GB Ram fast SSD etc so shold not be computer specs.
