How to simulate the load perpendicular?
This stone panel is 65" high, 1.25" thick, 31" wide. 300LBs The weight of the stone panel sits off axis, there are some steel plates on the rear bottom and underneath the stone towards the rear, the angled steel track pointed downwards is where the load sits. Because it is not centered, the load will want to make the panel fall forwards. I need to find out how to determine how much load(pounds) is being exerted perpendicular at the top of the stone while the stone is straight up vertically positioned as shown in the photo with the steel rail touching the ground. Is this possible in fusion? Thanks
