spring-lock design
spring-lock design
AagAag
spring-lock design
AagAag
I have designed a smartphone holder (downloadable design: https://a360.co/3Hf8D8g). It works well, particularly when printed on resin with a Formlabs printer, but the lid closing mechanism could be improved.
I was thinking of designing some kind of spring-loaded mechanism, with a very light spring (max 6mm diameter), and I am searching for inspiration. Any tips that you might be able to give me?
TheCADWhisperer
@AagAag
You are not using computationally efficient modeling techniques
and
are all of your sketches fully defined?
Are there any unresolved issues highlighted on the Timeline?
AagAag
yes something got screwed up at the last iteration. I will fix it, but first I'd like to decide how to lock the lid.
TheCADWhisperer
First - I would have to start over - using what was learned from this attempt.
AagAag
Actually my problem is that I need to design some kind of snap lock and I was hoping to receive some input on that. Once that is decided, i could starrt over (or fix the existing design). Maybe something like this: https://a360.co/4jsu2Z1
