ruled surface direction question
cekuhnen
Mentor Mentor
cekuhnen
HI dev team
so ruled surfaces are a great addition for modeling since extrude is limited the way it works as intended in Fusion.
What would be great is to be able to extrude a surface along an axis like in the image below.
I struggle with really finding the correct angle to extrude it straight up, 45 degree, or horizontal.
That would be a great addition!
(Or lol make that part of extrude)
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
lee_sanders
Hi @cekuhnen
Is the direction option any good?
Lee Sanders
Technical Consultant
cekuhnen
@lee_sanders
Yes provided options are pretty good when I want to make a flange on relationship to the surface edge
like in the images below
but it is impossible to make a flange vertical or horizontal when the surface is not terminating the same way already like in the image below  you can see that I can eye ball a vertical direction only.
alias automotive has the ability to for the direction also use the world axis !
now obviously in the case above I can also simply draw the line vertical and revolve it.
but think about this in general as an ability to make the draft surface using the surface normal, tangent or whats missing along the world axis direction
Claas Kuhnen
