Strange shape
Strange shape
pivetta.n
Strange shape
pivetta.n
I'm tring to reproduce a table similar to the one in the photos but I'm not able to work with diffent plane and particular angles. Please have a look at the image. I can make the two hexagons, base and top, but the sqare tube profiles are very difficult to make. How I should proceed? which is the best way? I want to be able to change the hight ot he table and the dimensions of the hexagon and keep everything dimamic.
Thanks in advance for the help.
JHRendon
You can make a 3D Sketch. So if you have the bottom hexagon, then create the top (use parameters so you ca update faster the dimensions) when you have the top shape, create a sketch and make the lines as you see on the pictures. You can use pipe or sweep to make the solid.
JHRendon
Tal vez te ayude a darte una idea. Checa los parametros.
TrippyLighting
Here's a screencast detailing the process :
pivetta.n
Hello @JHRendon ,
Thanks for the file also this si a big steo forward... I tried to use 3d sketch for the first time but I was not able to use it because it looked like that I hado to find the angle first, but I didnt kno the angle. Can you reccomend a tutorial video? Also the structure that you did has tuisted tubing ( I want to avoid that), it is more difficult then what I thought.
I already made this drawing with sketchup and I made it quicly because the 3d sketch.
JHRendon
You can use Sweep instead Loft then. 🙂
So with parameter you can change height, tube dimensions, hexagon dimensions too.
chrisplyler
Here is a version that doesn't use any 3D sketching. Only 2D sketches. With a few parameters, just so you can see how they work if you don't already know. It's just a rough intro...you would have to decide how/where you would want to trim the various pieces to join up.
https://knowledge.autodesk.com/community/screencast/3e78a950-ab41-489e-b97b-8ca5da304c08
