We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Rubin vases
Rubin vases
Lamppis
Rubin vases
Lamppis
Is there an easy way to model Rubin vases with multiple faces? Like in https://www.fahzface.com/pages/creating-a-fahz. With a single face it's easy as you just draw the outlines of the face and use revolve tool. Obviously one could use 180 degree revolve from both faces but then the model isn't smooth.
chrisplyler
Lamppis
Thanks!
I_Forge_KC
@Lamppis
If you use a complete circle for your guide rail and select the closed option in the loft dialog box, you get rid of the mirror operation and the funky seam.
K. Cornett
Generative Design Consultant / Trainer
chrisplyler
Good call! I had not experimented that far.
