round arrangement not possible
kellerkind-86
Message 1 of 16
kellerkind-86
hello... i am trying to create a round arrangement.... unfortunately i had the problem again and again, that either an error message appears... c- arrangement or it funkioniert but nothing happens... I have made a video where you can see what I mean...
thank you
(view in My Videos)
Replies (15)
Message 2 of 16
laughingcreek
the dialog box for pattern doesn't show in your video, so we really can't see anything useful.  you could export your model as an .f3d and attach.
Message 3 of 16
kellerkind-86
sorry... here the right video.( had to use another recording program)
i always get an error message
c order 5
(view in My Videos)
Message 4 of 16
davebYYPCU
Cut the single body first, then pattern bodies.
Might help...
Message 5 of 16
kellerkind-86
actually i want to do it this way because i think it's faster... but it doesn't work....
can someone explain this to me ?
(view in My Videos)
Message 6 of 16
TheCADWhisperer
@kellerkind-86
Message 7 of 16
kellerkind-86
here pls
Message 8 of 16
TheCADWhisperer
@kellerkind-86
See Attached.
Message 9 of 16
kellerkind-86
how did you do that now?
Message 10 of 16
TheCADWhisperer
Review the Timeline - it is all recorded in the Timeline.
Message 11 of 16
kellerkind-86
can't see it exactly... you created bodies ? did you delete the other bodies before ? but can't you explain to me why this doesn't go through elements ?
Message 12 of 16
TheCADWhisperer
I am shutting down for now.
I will try to come back later and explain in detail.
One key was to Pattern Faces in the disc.
Message 13 of 16
kellerkind-86
so. i did it a little differently now... but please explain to me why this no longer works with elements ? there is an error or ?
(view in My Videos)
Message 14 of 16
etfrench
Simplest method would be to draw the half lap cutout in Sketch3 and exclude it from the extrusion.  After that, combine/cut that body from the ring.  Pattern the combine/cut feature.
ETFrench
Message 15 of 16
kellerkind-86
thank you... i would like to do it with fusion 360.
and actually I would like to know why THAT does not work ? so that in the video
Message 16 of 16
laughingcreek
we can't tell from the video, and your latest attachment doesn't seem to be exactly the same file, but I would guess that the combine feature you are patterning is cutting a notch in the side brace?  in that case the pattern isn't working b/c the combine is set to cut from a particular body.  it's not going to cut from other bodies.
I also don't understand why you have each side brace as a separate body.  are they not all identical to each other?  make one component and pattern the component. see attached model
