- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This must be simple. I have searched and can't find the answer.
I have a simple (parametric) cabinet design where the various elements are components. If I rotate one of these components, everything is fine, until I change a design parameter that results in a change in position of the component being rotated. The rotation axis remains fixed in the overall model space, so the rotated component ends up in completely the wrong location.
How do I ensure the rotation axis is relative to the component coordinate space, and not the overall model space?
Images show the original
With the component rotated along its lower edge
And then with the height parameter reduced, which results in the rotation moving the component away from the rest of the assembly.
