Navigate Data Panel by Keyboard
sean.motyl
sean.motyl
I have a long list of Projects.  I'd like to jump around the list by Keyboard Letter Entry.  Has anyone done anything close to this?
I do pin active projects.
Sean.
vinayak_dhame
Hi @sean.motyl ,
Please refer the link below to search for the files and its location quickly in Data Panel.
Link
Let us know if this helps.
If my answer helped, please 'Accept Solution'
Vinayak Dhame
Autodesk Fusion
sean.motyl
Thanks.  Yes, I understand how to search for files.
I want an easier way to get to the lower portion of the long list of projects with scrolling or manipulating the slider bar.
Windows navigates a long directory list by having the directory window active and pressing a letter on the keyboard to quickly get to files or folders.
I'm looking for a similar functionality.
Sean.
vinayak_dhame
 Hi @sean.motyl ,
In data panel , at present,we can use Search option or Scroll using the scroll bar in the Data Panel to look for the files.
That functionality—pressing a letter key to jump to a section of the project list—is not currently available in Fusion. However, your suggestion makes a lot of sense, and we'll look into proposing it as an enhancement to improve navigation in long lists.
Thanks again for sharing !
Vinayak Dhame
Autodesk Fusion
