Rotate and sweep simultaneously
etfrench
Mentor Mentor
etfrench
Is it possible in Fusion 360 to rotate and sweep simultaneously.
Screencast: https://knowledge.autodesk.com/community/screencast/c2be5d49-bd60-4ac7-be66-75b4b1007a4f
This is a model of a hypocycloid globoid worm gear.  The gear pattern needs to rotate at the pitch of the worm.
ETFrench
TrippyLighting
http://forums.autodesk.com/t5/design-validate-document/how-to-create-a-toroidal-coil-helix/m-p/59124...
http://forums.autodesk.com/t5/design-validate-document/having-a-problem-with-sweep-and-flex/td-p/626...
These threads should provide some pointers that can help solve this problem.
For example if you sweep the tooth-profile around a circle and use a spiral as the guide rail for the sweep that could work.
etfrench
Thanks for the links.  I'll need some time to digest it all.
ETFrench
