Message 1 of 9
- Mute
- Permalink
- Report
in model mode I created a cube and used the shell tool to get a kind of box with upper face removed.
Now I created a rib using the rib tool. So far no problem.
Now I want to rotate the rib. But I don't know how.
If I use the move manipulator and select the part which is for rotating then the whole cube is selected for rotation. But I just want to rotate the rib inside the cube so that it is no longer perpendicular to the boxe's walls.
Thanks!
