Question on cloud renders
big_red_frog
big_red_frog
Hi There,
Is there a way to manually set the view angle or submit a view to the cloud render in fusion 360?
These previews are really nice and also handy for quick illistration, however, this piece which is at the back of the larger model it is embedded in ( everything else is hidden ) is rendered from behind, I would really like those front, and front, top corner views.
I suppose I could export the sub assembly and manually position in a new design, but wondered if there was a simpler way to do things.
previewRenders.PNGThanks.
big_red_frog
Note for my immeadiate needs, I exported the part assembly into its own design, turned it around 180 degrees and cloud renders are good.
Oceanconcepts
As I understand, if you go to the Named Views in the Browser, RMB and create a New Named View, that view will be included in the cloud renders.
- Ron
Mostly Mac- currently M1 MacBook Pro
big_red_frog
Now you have stated that, I remember it being commented on elsewhere ( I did try to search the forums before posting this! )
Thanks...
Oceanconcepts
It was on the Blog, and in the Hangout.  So much information...
- Ron
