Revolve Sketch Around a Spline
I have created a hollow cylinder by using a Spline and sweep commands within the Model workspace. I then created a sketch that I want to revolve around the spline that I used to create my pipe. When I attempt this however, I cannot select the spline as my axis and I couldn't find ways to convert my spline into an axis. Is there any way to revolve a sketch around a spline?
Thanks in advance for your help!
Hello Fedman15, I hope that I can help you
From your image, it's look like that your axis for revolve is not linear and I think axis for revolve is must a linear (straight line). I just tried this with image below. I think sweep is better instead revolve in this case if you want the axis to be spline (maybe, I'm just a beginner Smiley Happy )
Revolve
By the way, can you help me to give the "Like" to my design in the links below?:
1. https://fusion360.autodesk.com/projects/kujang
2. https://fusion360.autodesk.com/projects/akik-indonesian-gemstone
3. https://fusion360.autodesk.com/projects/delman-style-lounge-chair
I am participating in Autodesk Fusion 360 Competition in Indonesia. Thank you so much!
Best Regards,
Arif
