Revolve on bad way
Revolve on bad way
tomas.mlcak
895 次查看
4 条回复
1 条消息(共 5 条)
Revolve on bad way
tomas.mlcak
i have problem with revolve fuction. I need revolve profile to plane., but on reverse way.
On screen, i select profiles, axis a select To and select profile. Fusion revolve to green arrow, i need revolve to red arrow to plane under second red down arrow.
How can i do?
0 个赞
已接受的解答 (1)
896 次查看
4 条回复
回复 (4)
2 条消息(共 5 条)
davebYYPCU
Instead of "to" for angle
you can do Angle with +90 or -90 deg - or measure angle first,
when I test, I can only go one way with "to" and it was same as +90 deg for me.
Might help
0 个赞
3 条消息(共 5 条)
tomas.mlcak
There is big problem. Plane isn´t on axis.
This is viw on screen with section view.
Angel is diferrent between red-red line and red-green line...
0 个赞
4 条消息(共 5 条)
davebYYPCU
已接受的解答
Okay,
make revolve past red line as new body,
use Plane to split body, and hide / remove / delete lower part, then join new correct piece etc.
does not fix bug in revolve, but might get you going again
5 条消息(共 5 条)
tomas.mlcak
That is also the possibility.
I have it done.
Maybe I raised my question (request) as an additional feature to Fusion 360.
0 个赞
