- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am attempting to cut this groove in the curved face of this part. I've tried Sweep and Revolve both with a bad results.
I tried the revolve by creating an axis through face and point. I used the right side of the part and the center point of the radius for the face. When it cuts its not using the axis I selected therefore it only cuts part of the face. In the screenshot the orange dotted circle should be the path. I read a forum post that someone had a similar issue and the response was "You have picked the side of a body that does not go through the axis as your profile." which I don't understand.
Then I tried sweep using the profile and the edge of the face for the path. It cuts however it doesn't cut all the way through, the bottom is closed. I know it has something to do with angle of the profile but can't figure out how to fix.
Any input would be appreciated.
