I'm still struggling on with my slot together kangaroo mechanism. I'm determined to get it working!
I have traced out the shape of the body side onto a sketch. There are two axle holes which I assume need to be constrained into position. (yes?)
I've added dimensions between the two holes but cant work out how I can fix them in position.
I'm guess I need to add a horizontal and vertical construction line that touch the body then add dimensions from those. Is that the best way of doing it and if so how do I make these construction lines so they touch the body?
Sneaky second question. I need to create a plane that runs at 45 degrees through the circular hole below. I'm guessing I need to make a construction line across the circle ? If so, how do I do that!? Or if not, how do I best make the plane?
Thanks in advance! I really do appreciate the help I have been receiving on this forum as I have been struggling up the nursery slopes of F360. Thanks everyone!
I've attached the roo file below.
