Revolve command for open curves ??
Message 1 of 8
How do I create this as in the Tutorial?
I can't select the curve for the Revolve command.
I can make a pipe out of this curve and a few other commands work, but Revolve does not.
However, If I make the curve a closed shape it works wonderfully.  But that's not what is shown in the tutorial.
What am I doing wrong?  I thought it might be 'create 3D sketches' check box but that didn't help.
I've also watched this video and still have no idea what he is doing that I cannot replicate.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-5C62F370-7AB4-4DFD-BE61-F8830F30A6D7
Replies (7)
Message 2 of 8
dsouzasujay
Hi @Anonymous,
I have created a screencast to demonstrate the T-Spline revolve, I was able to successfully create it.
If i'm missing something please let me know.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 3 of 8
lichtzeichenanlage
my guess is, that the TO is in Model mode and not in sculpt mode.
rgds - Wilko
Message 4 of 8
As a new-be, I sure wish I knew what "TO" meant.
I would think that you are automatically in sketch mode when you draw the spline curve under the sketch.
I would also assume that the software automatically switches to sculpt mode when you use a function (Revolve in this case) under the Create drop down.
There is no other way, that I see, to switch from sketch to sculpt mode.  If you are using commands under the sculpt drop down, you must, automatically, be in sculpt mode. That;s my assumption.
TO?  is that Tool Option
rgds - Wilko
Message 5 of 8
Thank you,  This was VERY helpful.
I only wish I could view your screencast in a larger format.  It was very hard to see but it did the trick.
Message 6 of 8
lichtzeichenanlage
I'm a complete Fusion 360 new-be, too. "XX" is an acronym for thread opener - at least we do use it in germany for that 😉
Message 7 of 8
lichtzeichenanlage
Don't forget: I'm totaly new to Fusion 360. So what I say ist just my current understanding...
The default start mode is model. If you call the spline function a sketch will be created and you can draw your spline. But IMHO this is a bad way to create a sketch because you should define the plane on your own or you will lose a lot of possibilities. If you than stop the scatch you are back in the model mode again. Often you will now create a body by using a function below the create menu. And you will find a revolve function under create. But this only works for closed profiles. Why? Don't know but my guess is, that bodies are closed by definition
You will also find a revolve function if you switch from model mode to patch. But this will not work with open pathes either.
So go back to the model mode and create a form. Then you can use the revolve function under the create menu and you will get your form.
Message 8 of 8
dsouzasujay
Hi @lichtzeichenanlage,
In 'Model' work-space, Revolve only works for Closed profiles. To create a solid body.
In 'Patch' work-space, Revolve should work for both closed and open profiles. Creates a Surface body.
Note: Closed surfaces (Stitched) will convert into a solid body.
@marchitect1HXAATYou can maximize and Pause the screen cast to get a better view.
Highlighted in RED box.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
