One way dimension
One way dimension
etfrench
Mentor Mentor
One way dimension
etfrench
The dimension on the largest circle can be increased, but fails miserably when decreased. Since the circle was originally smaller, decreasing the diameter dimension should be valid.
ETFrench
FrankCao
Hi etfrench,
Thanks for reporting this issue. This looks like a bug in sketch solver. Could you help attach your file here or send it to weining.cao@autodesk.com for us to go on analyze your issue?
Frank
etfrench
File is attached
ETFrench
FrankCao
Hi etfrench,
Thanks for posting the model. Now I have reported FUS-33095 internally to track the problem and have sent it to development team to take a look.
Btw, I find that if you gradually change the value from 90 to 88, then to 86, 84, 82... finally you can change it back to 80.  It seems sketch solver still has some problems when solving big dimension value change in some special sketch.
Frank
