revolve body(solid) , not sketch or curve
srevah
srevah
hi
please watch my video
there is donut just revolved
can i revolve that donut ?
it is similarly imagined with circular pattern with big number.
davebYYPCU
Modify a Sphere.
Might help...
MRWakefield
You could potentially use the new "Solid Sweep" function.
There are some caveats though. I swept this along a circle but it wouldn't allow me to use the whole circle. Consequently I had to sweep along half of the circle then perform a mirror.
Not ideal but it might work for you.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
TrippyLighting
See the attached model.
2 sketches and 2 revolves.
srevah
thanks but hard to understand intuitively
JamieGilchrist
Hi @srevah,
Peter (@TrippyLighting) took your desired result and distilled the shape into a simple sketch (while referencing your original "donut") representing the net shape to revolve.  This is a much simpler and more robust way to model than the solid sweep method.  Keep in mind that a parametric model has to keep track of every sketch, dimension, feature, move, etc., which will accumulate compute time as more complexity is added;  a good rule of thumb is to keep your sketches as simple as possible and create your models with as few features as necessary.  There will be dozens of ways to approach making a shape like this, but the best one is the simplest one (which Peter shows, IMHO).
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
