multiple design from original with maintain design history
srevah
srevah
hi
i want
multiple design from original with rules
for example
please watch my video
there is holes diamater increase 10mm
draw 3 holes , dimension 3 hole , and extrude
but i wonder there is rules that diameter increase 10mm
so like pattern , is that possible to draw 2 hole easily
like draw 1 hole, and  draw 2 hole automatically
and similarly
there is 3 holes with 10mm diameter.
but extrude height is increase 10mm also
so if possible , want to 20mm, 30mm extrude from 10mm extrude easily
thanks
TrippyLighting
That would be called procedural modeling and is not possible with Fusion.
you'll have to create these cylinders (for example) individually and dimension the individually.
There is no pattern "rule" that will automatically increment dimensions for each patterned instance.
