Revolute joint cylinder around a smaller cylinder through
I've been looking through the forum and I can't find a solution.  I can't seem to rotate the landing gear around the smaller pin/cylinder.
Any help would be appreciated.  Should be a screenshot attached.  thanks!
I tried grounding the pin but that doesn't do it either.
Beyondforce
Please attach the file and I'll show you how to do that.
Ben.
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
jeff_strater
The only thing I can see from your image is that maybe you don't have separate components defined for everything?  It's hard to tell from the picture, but you would need a separate component for the pin, and for the rest of the landing gear.
Here is a very simple version of one way to do this:
Jeff
Jeff Strater
Engineering Director
