Reuse inputs in Simulation
I have entered several input data in my thermal simulation in terms of materials, loads, contacts and the like. Now I want to switch to a thermal stress analysis with the same model and I would like to keep the parameters I've already input. Is there a way to do that?
Thanks in advance
tomasz.kasperek
Autodesk Support
Autodesk Support
Hi, @Anonymous
Can you share me the model?
Tomasz Kasperek
Technical Support Specialist
My Screencasts | Fusion 360 Webinars | | Troubleshooting
sorry for the delay in the answer. Attached you find my model
Regards
Right click and clone study...then you want to go into the settings of the new study and change the type to whatever you want.
