Export Fusion to Archicad
MrtnST
MrtnST
I need some help with figuring out how to export my model from Fusion 360 to Archicad object format (.obj).
I know there are several file formats that can be exported from Fusion but when I compare them to what Archicad is compatible with It doesnt give me much help. https://helpcenter.graphisoft.com/knowledgebase/25765/
It seems like it is only .dwg, sketchup and 3d-printing format that could work. However when I tried .dwg almost all information was lost. So I tried export it as a sketchup file and that went well but the asigned materials was lost. And also it doesnt feel like the best solution to use sketchup. Does anyone have any ideas?
tomasz.kasperek
Autodesk Support
Autodesk Support
HI, @MrtnST
How you do it currently, directly form Fusion or from HUB in the browser?
Tomasz Kasperek
Technical Support Specialist
My Screencasts | Fusion 360 Webinars | | Troubleshooting
MrtnST
I exported from  the browser and I belive that is the only way to get access to all exported formats, right?
@tomasz.kasperek wrote:
HI, @MrtnST
