Simulation Question
Simulation Question
Simulation Question
Be aware that this will be a begginer question! I´m having some troubles with the simulation. Displaying a safety factor less than 1!
The question is:
Should I manually define the contacts after to define different bolt connectors?
In my model I did like this: I put different bolt connectors and then I selected ´automatic contacts´. But I am having these poor results!
Thank you very much for the attention!
Regards
tomasz.kasperek
Autodesk Support
Autodesk Support
Hi, @Anonymous
Can you share the model or attach the screenshots?
Tomasz Kasperek
Technical Support Specialist
My Screencasts | Fusion 360 Webinars | | Troubleshooting
Here is the file,
Thank you for the attention.
What does the bolt connector if it doesnt automatically apply a contact when we select ´´automatic contacts´´´?
